I just recently replaced the abs hubs on mine. I disconnected the abs hub plug without the battery disconnected, the reconnected it. This caused the tracc control and abs to disable, when l tested it just the low tracc on the dash strobes when wheel spin is sensed. So l disconnected the battery +&- for some time. Reconnected it, tested and abs, tracc control also throttle relaxed activated. It can also be reset/disabled on a tech 2, not a ebay job.Hey i had the common fault with the vt's and abs modules where the lights on the dash would come on and the car would stall etc. abs, trac control and cruise control would not work.
I have since replaced the faulty module with a changeover one from ebay and have installed it today, but the abs and trac cntrl lights are still on but the cruise cntrl now works, so half the problem is fixed.
I took it for a drive and was still able to lock it up and spin the wheels so its not just a bulb problem. the cruise control works fine.
Is there something i should have done like reset the computer or pull out a fuse and put it back in?
the whole thing was working fine before the module stuffed up originally.
cheers Sam
