Airbag light VU help
TraceyTorana
Vu Maloo
I have a VU with an airbag light, it error was 163 I think, it was to replace the module.
I had this replaced, then when I check it now with my Tech2 tool it says no faults, but when I try to clear the light it won't clear.
Any ideas on what it could be or help please.
I was told about making sure it has enough loops, how fo I check this & clear my airbag light from going off.
The fuses seem fine
lout
Langwarrin Victoria
VX Executive S2
i have heard of similar before
unplug a seat belt pretensioner or side airbag if fitted
turn ignition on and then off
replug seatbelt pretensioner or side airbag
you will have now set a code
when you clear this code it should also turn the light off
the part number of the srs module should be for the number of loops you have
  • Like
Reactions: Lex
TraceyTorana
Vu Maloo
Thankyou is that the number in the corner of the module, utes have 4 & sedans have 6, is that what the number on the corner of the module is.
Thanks I will try what you suggested.
How do I know how many loops are in my VU...what do I count..
Can you explain what a loop is please, its driving me loopy.
I only know about older Holdens
I appreciate your help
Thanks again
TraceyTorana
Vu Maloo
Where exactly is the seatbelt pretentioner exactly. Sorry I am just learning
lout
Langwarrin Victoria
VX Executive S2
steering wheel airbag, 2 pretensioners = 3 loops
2 Airbags 2 seatbelt tensioner = 4 Loop srs
4 Airbag (2 are side airbags in the seats) 2 seat belt tensioners = 6 Loop srs
seatbelt pretensioner is the cylinder attached to seatbelt buckle, next to console
srs module is under console
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
It's the part where you click the seat belt in, next to the console.
Edit. I'm a few seconds late.
TraceyTorana
Vu Maloo
Thanks for trying to help me, how do I tell if it hss airbags in the seat?
Also what about the glovebox, do theyhave 1.
Sorry for so many qustions.
Does it being a Maloo make any difference?
Thanks so much for trying to help me.
It is doing my head in.
TraceyTorana
Vu Maloo
Also thanks, I replaced the module under the dash, that is what error code it had.
TraceyTorana
Vu Maloo
Thanks for your help, it didn't come on today, hopefully it won't come.on again.
If so i will try what you suggested
TraceyTorana
Vu Maloo
I replaced the Module it had a number 4 on it. Being VU it was a different part number .
Is there an airbag in the passenger side console in a VU May 2001 build.
Thanks again.
The module I re
