Ricstar
- Aug 19, 2019
- 3
- 0
- 1
- Age
- 59
- Location
- Brisbane
- VT Calais
Hello.
Alarm going off intermittently. Eg after say 20 minutes or sometimes 8 hrs.
What i have assessed so far:
After Alarm has gone off. Returned to car and pressed unlock from Fob. Put key in ignition.
LED flashes are as follows. 3,3 4,4 5,5. Now from the car manual that 4 flashes is Passenger door either front or rear, 5 = drivers door and 6 = hot wire attempted. But nothing tells me what 3 Flashes, then 3 flashes, then 4 flashes, then 4 flashes, then 5 flashes, then 5 flashes, then cycles back to 3 etc.
As I have a Calais, I have the BCM - High whereby the door switches are double pole. So provides a circuit for the door light as well as signal to the BCM for the interior Dome light.
Battery voltage is 12.55 to 12.7v. These voltages at rest are the same as my Pajero. I can get higher If I plug in a CTEK charger to bring up to 13V.
Another symptom is that the interior light on DOME sometimes is on, even though doors are closed, Bonnet and boot, glovebox and centre consoles are closed, including after turning the ignition on, or waiting 30 seconds timer so BCM turns off the DOME /earth circuit.
I can turn off interior dome by moving the switch to off.
But the consequence of this issue is that when the dome light can stay/be on and as the BCM is providing earth to the dome circuit, the key fob cannot lock the doors as it thinks the/a door is open.
I can still manually lock the drivers door which in turn locks all doors and does this without arming the alarm. I just have to switch the dome light to off so as to not flatten the Battery.
thanks to this forum, i have the Wiring diagram for the Interior Illumination circuits
I have tested all door switches. Thanks to someone who posted and uploaded a ZIP file with wiring diagrams. I can turn off the dome light/force the BCM to turn off the earth to the dome circuit (So go open Cct) by having the drivers door switch unscrewed and out. If I have the double switch contacts so the wire going to the BCM White/Blue - (0v/earth) - connects to the Door safety lamp - White wire (12v) the interior Dome works normally. However based on this, if I also then have the switch to body earthed as it would be screwed into the door pillar, the BCM does not disconnect the DOME output circuit to open Circuit and so keeps it earthed so Dome stays on when switched to "Door"
I also tested all wiring from Door switches to BCM and no shorts. Asso no shorts from other lamp buttons, e.g. bonnet, glovebox, centre console, boot.
Whilst I have the Drivers door open and switch removed, but just connecting the BCM -White/Blue 0v/Earth to the Door lamp 12v White and NOT the body earth via the door button screw, opening and closing all passengers doors, the Dome light works as usual. No faults. As each door switch is double pole, the wire going to the door lamp is 12v as expected via the door lamp to 12v circuit and the 2nd wire back to BCM trigger - White is 0v.
Note, my VT1 Calais with BCM-High does NOT have an Illumination Relay and I believe it is internal to the BCM. I can hear it click when dome goes on/off, etc
So I would love some feedback and advice.
1) What is the 3,4,5 LED's mean?
2) Anyone have the section on the tech manual for the BCM, Illumination and Alarm with fault finding/test processes?
2) Anyone know of someone in Brisbane who can Run diags on the BCM and not want an arm or a leg or sacrifice my first born child? Local dealer wants an hour labour just to read BCM codes, but says his techs are not experienced anymore with the VT so cannot guarantee and most likely will not know what they are doing but confirm, they are aware of how to bill me for the pleasure.
I think If I can resolve the DOME light issues, it will fix using the key to lock doors / Arm the alarm issue.
Appreciate any feedback and thoughts.
Thanks In Advance.
Rick S.
Thanks In Advance.
Rick S.
