amppp hellp
Fun_Bucket
Cairns White Rock
Cruze II sri
so 13 was the radio fuse, but if the accsesoroes fuse is blown, then it wont work either, i cant tell you what number your accsesorie fuse is, because i have a VP, there different..
Fun_Bucket
Cairns White Rock
Cruze II sri
If you've connected everything back the way it was, then theres no reason why your head unit wont work other than a blown fuse. Theres also a fuse on the back of your head unit, check that too.
If you cant connect the wires as we've said above, or locate your accsesories fuse, then you going to have to take it to a specialist, because you can only explain so much on here, with out being there to show you..
MAC-VN
vn90
ok ihas the accs got its one fuse as well under streering wheel or in motorbay?
n i have taped everything same n not working so it must be fuse somewere
Philthy
That dent guy
www.qbdentfree.com.au
3.0R Liberty, XC Falcon
That was my next idea as well. It may be hidden underneath the plug on the back of the headunit if you can't find it.
I can't think what other fuses there are under the steering column, but it will only take you a minute to check them all, then you can at least rule that out.
MAC-VN
vn90
only fuse i found blown was the ciggy lighter
i cldnt find on on head unit gonna go look under the plug
Fun_Bucket
Cairns White Rock
Cruze II sri
Philthy i think your gonna have to pop around some time for him, and sort it out. It's too hard to explain everything over here.. It's most likely something really simple, that if we were there, we would identify straight away, but could be here for hours, with no result, like this. You had it working, but you had the REM connected to the ISO's 12 v wire, rather than the cars accsesorie wire..And now you've blown a fuse somewhere..
MAC-VN
vn90
well fuse on the headunit is fine
MAC-VN
vn90
cld the headunit be wired to the ciggy fuse or na cos thats only fuse i can find thts blown
Fun_Bucket
Cairns White Rock
Cruze II sri
Replace it anyway, because its accsesory related..You must not be connecting everything probably, so i dont really know if i can help you much more. Its possible that when removing your head unit,
that the connectors in the ISO plug have come loose, i've had this problem before..
VQXTC
3rd planet from the Sun...
HSV VP Senator, VY SS Crewman
Hey there MAC VN,
If the Sony unit has 3 blue wires........
The wires should be as follows....
Dark Blue - Electric Antenna....
Dark Blue/ White Trace or stripe.... - REM (connect to amplifier)
Light Blue - Telephone Mute
Let me know if this is what you have....
Simon
