amppp hellp
Philthy
That dent guy
www.qbdentfree.com.au
3.0R Liberty, XC Falcon
The yellow wire should be behind the headunit, probably slightly larger than the other wires coming out of the headunit.
That should get power whenever the key is in the acc position, so you know the remote wire is sending a signal
Yeah, this site is great. It's taught me pretty much everything I know about cars...well that and just going out and having a go
MAC-VN
vn90
ok ill go do it now ill be back in about 5 mins to tell u how it went
MAC-VN
vn90
it worked woooo hoooooo ahaha
new it was the bloody rem wire n earth
thank you guys so much thanks so much
i owe uses i shall let u how how getting the hole interror back in goes ahah
MAC-VN
vn90
one problem the amp is consently on now ahah
so thts gonna drain my battery wat do i do
Fun_Bucket
Cairns White Rock
Cruze II sri
The amp should only be on when the ignition is on, is that whats happening now? Unless you connected the REM from the amp to the power wire, rather than accsesories
MAC-VN
vn90
well it was the yellow wire on back on headunit
so wat one does it need to go to n were
Fun_Bucket
Cairns White Rock
Cruze II sri
were getting mixed up now, so your amp works, and we know its not a power/earth or fuse related problem.
Its the on/off signal being sent to the amplifier. Is the amplifier on, even when your ignition is completely off?
MAC-VN
vn90
yeah well the blue light is on the amp so yeas
and unless it take a while for the blue light to go off then yes its not going off
Fun_Bucket
Cairns White Rock
Cruze II sri
then you've connected it to the constant power wire, and not the accsesoires wire..You should have a yellow wire, and an orange coming from the cars harness( not from the head unit..) the yellow is for accsesories, the orange is a constant 12v wire. Does your Head unit turn off properly when you take the key out?
MAC-VN
vn90
yeah it turns off fine
the yellow is coming from the harness maybe the yellow is the 12v con n the orage if the accs
n were the yellow wire comess (the harness the clips into back on h.u) it goes for abit then its sticky taped cos feels like its been slipt into to wires
