2O4TS
!2.3 volts could be a little low, have you tried another battery?
The young fella here got a brand new battery for his VT yesterday morning. 550 CCA as is mine. Cranks like a champion. Checked the voltage on that, 12.7. Can understand mine being down a touch not being started for near on three weeks now but at the least you'd think I'd get the flat battery click with 12.3. Might still try that though 'cos I'm at the point where almost anything's worth a shot. As I posted earlier my roof light does seem abnormally dull so who knows.
Interestingly, I removed the starter relay from the other VT and swapped it for mine for testing and after we pulled it out and attempted to crank the other VT the sounds from the engine (which I'm assuming are coming from the injectors primarily) were identical. It seemed very similar overall except that he has lights. My indicator relay clicks once when I flick on the indicators or hazards but that's it. No flashing at all. I have to re-wire the lights in the boot anyway as the WH uses different plugs so perhaps there's the possibility that because I only have one indicator connected the resistance is too low for the flasher relay to work properly? Due to the strange issue I have with the lack of length in the wiring for the thermo fan I'm yet to wire the passengers headlight and indicator as well but I would expect the drivers headlight to still work, ditto with the indicator unless the resistance is just too low. The WH also has a single plug for the combined lower indicator and fog light assembly so I need to sort which is which there eventually to connect my fog lights but again, very low priority. I think I might head back outside a little later and swap batteries again.
I really prefer it when stuff just works the first time but this is pretty much par for the course for me in so far as if something can go wrong it usually does. Good experience I suppose 'cos I rarely make the same mistake twice. Everything else has been as expected or even a touch easier so by the law of averages some part of this little job was always gonna bite me!
I'm really looking forward to letting you all know what I've stuffed up! :yeah:
