2O4TS
the D plug now becomes the E plug all you had to do was match (20 wires) the colour to colour to the plug is the same, it doesn't change, very simple and the climate control is controlled by the control electronics and not the BCM
but hey what do i know
And what about the other two plugs? Seriously. This is basically why I said your post was of no value to me. Here's the reality. Now maybe, just maybe, I could've cut and soldered a whole stack of wires and re-wired or 'Frankensteined" my BCM set up but I chose not too, preferring to only detach and re-attach the light sockets as that is quite simple and I'm happy to admit I'm not an auto electrician or electronics expert by any definition.
The fact is your post above makes no sense to me at all. So the 'D' becomes 'E'. Righto, so I pulled the BCM and tried to match it with my original BCM and here's what I found.
Note, only two plugs fit in to the BCM from my original loom. That leaves 3 sockets with no matching plugs/wiring to go so if I just swapped BCM's without running the appropriate loom I'd have three empty sockets and dare I say, a whole bunch of stuff that wouldn't work at all. The way I chose to go, every plug has a socket to go in. The socket it was designed for from the same car the BCM came from. Keeps it as standard and as simple as possible. According to multiple posts I read here before attempting this (which I would not have attempted without the advice) I needed to upgrade my BCM to either a lux or high level BCM. I repeat, I'm not the first to do exactly this but I don't see you bagging any of the other posters who've done it exactly as I have (bhopper 2.5 years ago for example). I chose the high as then I could plug in absolutely any option I chose without more cutting and soldering. Eventually I'll have the full compliment of air bags and side impact sensors as well, and I'll just plug 'em in and 'voila', just like everything else so far as the climate is working fine and so too all the other accessories I've just installed. No cutting, no soldering, no trying to sort wires, just plug and play.
So here you can see the two plugs from my original loom that will fit into my high BCM inserted into the high BCM. You will then note that I have one remaining plug on my original loom which does not fit into any of the remaining sockets on my BCM as I have demonstrated in photos 2 and 3. Now since I was informed via my reading here on JC that I had to upgrade my BCM in order to have climate (and when I see the 20 odd wires in two looms hanging out the back of the module I can see why that was recommended particularly when I've not found any instructions anywhere on how to patch those wires into a mid level loom) can you not see how it was simpler to just run the whole loom? It's a relatively simple job AFAIC compared to working out where the plethora of extra wiring goes for all these higher level options then cutting and soldering them all. I think my way simplifies the whole deal.
Now I'm more than happy for you to give me a detailed rundown of how to install all the high level options with my original loom without upgrading the BCM and/or exactly and I mean specifically install the high level BCM without the corresponding loom but at this point in time your description that "D becomes E" is of little value to me without considerably more detail. Therefore at the moment and until such time as you can correct my reasoning by supplying me with those detailed instructions, I stand by my method of replacing the whole loom and BCM. If you have an easier way, please, by all means, spell it out in fine detail. I'm sure there are many more people here on JC that would like to know how to do it.
