any kill switch diagrams
leigh 7005
adelaide
vb sle
has anyone got any good kill switch diagrams or ideas i made one and conected it to my coil but it burnt out the switch why?
DANNY8
Yo Coooornflake!
34
Port Pirie, South Australia
www.kerrbrosracing.com
VK WAGZ 5.0L, GQ Patrol TD42
If the kill switch is for ur dirt circuit car, just use one of those big red narva paddle switches. Hook one side directly to the battery, and the other side run 3 wires, one being a fat cable to ya starter and a half decent one to ur coil (doesn't need to be huge, just don't use speaker wire or anythin lol), and a 3rd wire run through a push button, then to ur starter solenoid. Then u don't need to worry bout wiring it up through ur ignition.
I've attached a rough diagram. :thumbsup:
Zuicider
Banned
Stonedville
Set of thongs
good old isolation switch on the dash
DANNY8
Yo Coooornflake!
34
Nah they fit good in the window wiper hole....being a dirt circuit car u don't need them coz u got no windows lol.
vkberlina
VK Madman
41
NSW Central Coast
www.members.westnet.com.au
One I had on my coil once was a 3.5mm Mono audio socket on the dash near the keys. I had the mono plug on my Key ring and basically used it as a switch the plug was shorted inside and used the centre and shielding connections on the socket for in/out.
No one would notice it and if your in a fix and loose your plug you can use any old bit of wire to get you under way.
Also for commodores the autos have a neutral start switch purple wires from memory on the auto cut it and put a switch on it hides on the side of the console well. if a manual there is a loop at the front of the console wiring harness ready incase of an auto conversion break into it there.
cheers
Scott
leigh 7005
adelaide
vb sle
its for my daily driver dont know wat amp switch it was it was the old gas system petrol gas switch thanks danny for the insight on the kill switch for my dirt car.scott will my car still start if i hook one up to the netral safty switch?
leigh 7005
adelaide
vb sle
danny hows your efi 304 wags going have you started
vkberlina
VK Madman
41
NSW Central Coast
It will depend on switch position the switch on the auto will only allow the car to start in park or neutral so you cut the purple wire and put a switch on it so whent he circuit is broken it wont start.
cheers
scott
DANNY8
Yo Coooornflake!
34
