Update:Hi,
I have a series II VT Calais.
I've had intermittent Transmission warning light coming on for some time, recently this has changed to intermittent Traction Control light coming on and the button does not work to turn it off. Both those conditions go away after a re-start.
I've also noticed that sometimes the engine fan comes on when I start the engine - sometimes coincides with Traction Control light - if I turn engine off and restart it's OK again.
Yesterday while driving with air-con on auto the air-con suddenly turned itself off. I played with the buttons but no joy. I stopped the car and turned the ignition off and restarted the engine but still no air-con until I pressed the fan control button to max (by the way, all dash LCD readings or whatever you call them indicate fine). The air-con now only works if I have the fan control set to max and then it freezes me solid! Also, I can't select feet and face mode to divert some cold air away from my face.
I'm sure I saw in this or similar forum a couple of years back that all these symptoms are due to the ABS module? I've searched but haven't been able to find it again.
Anyone got some tips as to where to look and what to do? I don't want to spend heaps of $$ on this as I want to trade it in for another Calais (yeah, I know - slow learner).
Thanks,
Dave.
