Ask the EX-Holden Technician
Status
Not open for further replies.
holden_1
perth
VS V8 commodore
slippage on the auto trans
Hey doctor bob.
I have a 93 VR V6 Auto Berlina i have been doing some work to it, e.g: cold air induction, 2.5" exhaust, 70mm throttle body, memcal upgrade and msd ignition coils. But since i put the throttle body on it seems to feel strange changing from 1-2 and 2-3. it sort of takes a while to do it. but if i floor it, it changes perfectly and if i drive really slow the same thing but when i give it normal acc it goes all crazy on me. would it be a computer problem? or are the bands stuffed? is there anyway to adjust the bands on the TH700?
cheers m8
sp001in
vyma100
41
QLD
VY ute
I am after a holden mechanic to do some work on my v6 ecotec"s eg; hi ratio rockers throttle body, chip change and service , can anyone help me on the northside "Keperra Area" ph 0438774471 peter
torque performance brendale.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
Hey doctor bob.
cheers m8
throttlebody is messing up the shifts either need a tune to suit or remove the throttlebody
michaelw84
95 vs commodore spack ute
Vs Engine light and wont rev when accelerator pushed flat to the floor
hey guys,
driving home last night the engine light come on and i felt the car become sluggish, i then put the clutch in (while still rolling) and the accelerator was flat top the floor and nothing for about 1 second and then the revs slowly come up to where they were meant to be. this orrured until the time i turned the car off and tried starting again and everything was back to normal and the engine light was off.
cheers
mick
holden_1
perth
VS V8 commodore
thanx man so do i just need to get a dyno tune done on it do you think? and would there be any other problem do you think or would that be it?
cheers
Bozza
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
NO i meant the type of unleaded
i found a thread here or another forum, something about 91 and 98 type of fuel
either for long drives or city drives and what's best for the engine
Put the best that you can afford in. 98 has the benefits of *insert marketing hype here* but 91 wont do any harm.
vxman
Griffith
VX V6 executive S1
power windows
hi doctor bob.
i just installed power windows in my vx executive. i got the wiring looms for it. they were already under the centre console and to the door. but not in the door
so i got them. put all the fuses and relays in. put the power windows in place. and the drivers window wont go down. it is all the way up and you can hear it trying to keep going up but no noise at all going down. all other windows work fine. any suggestions??
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
hi doctor bob.
you probably need to change the BCM to one that has window control as the BCM controls the drivers window down circuit
vxman
Griffith
VX V6 executive S1
thanks for the answer. where is the bcm located if u wouldnt mind me asking
86vkcommo
86vk commodore
hay doctor bob i have a vk commodore black motor carby 202 ive put a new coil in it rotor button dizzy cap plugs and leads ive got power at the coil but still no spark at the plugs and checked all the cut offs were working
Status
