StephenM
- Jun 26, 2017
- 232
- 48
- 28
- Age
- 71
- Location
- Innot Hot Springs Qld. 4872
- VS Equippe Series II
Towing empty box 7 x 4 trailer. Sat on 90-95 kph.After about 200 k it revved to about 3000 and speed dropped. Slowed down and it seemed ok. It happened another three or four times over the next 50 ks. Checked the transmission fluid and added about 750 cc. There are no obvious leaks under teh car. Nothing sprayed back on the underside at all. Went for two drives of about 6k. Headed back home with about 200 kg in the trailer. After about 50 k it did it again. checked the fluid and it was OK. Seemed to be bubbly. 10 k down the road smoke started pouring out. The dipstick was a bit wonky and maybe I didn't ensure that it was properly locked in and it spat out and transmission fluid all over the engine bay and exhaust. RACQ got me towed home (140k) as the guys said it was a tranny problem and would take more than 48 hours to fix. The car has only done about 160,000k , mostly in Townscville city and suburbs. Not a real lot of highway driving prior to my getting it and was running OK until this. Would the low fluid have damaged the transmission or is it possible that the fluid had sprayed out quicker and the loss of fluid caused the issue. If it was manual I would describe it as a slipping clutch, but it was not consistent as a slippery clutch is. Any ideas. I have a local mechanic who has a 2nd hand box. Haven't spoken to an auto tranny specialist as yet as it only happened this arvo. Thanks in advance
