Changa
Alex Short
- Jan 1, 2009
- 170
- 1
- 0
- Age
- 33
- Location
- Hervey Bay, Queensland
- VS Executive
Thought I would update and say that I have fixed this problem, turned out to be an ignition coil (the middle one) breaking down under load and causing the car to drop a cylinder or two. Best way to test this is get at least one working coil and replace one at a time then going for a drive to see if the misfire disappears. I have a mate with a Lexcen same as the VR model so I just swapped in all his coils for mine and the problem disappeared. I then went to autobarn and got a one new coil for 65 bucks and started swapping my coils out one by one, till i found the culprit one, ended up being the middle one. This fixed the little misfire i had at lower speed and also the vibrate/shudder in 4th gear on the highway.
