BMW Center bearing compatibility With WL
Aalbloshi
Jeddah, Saudi Arabia
Holden Commodore WL / Caprice 2005 SS
Maybe replace the whole tailshaft.
Any weird vibrations when driving it? Any obvious marks where it might have been hit by something?
Nope, the Whole Tail shaft Looks good, I’ll give it a go Might Solve the issue, went to the Mechanic shop He Carefully Analyzed the Shaft And found no flaws in it. He Said He have A fairly new Shaft Laying around And he’ll Replace it for free Even if the same thing occurs then something is wrong idk what is it
Immortality
Staff member
Sth Auck, NZ
If the whole assembly looks good than maybe the centre bearing is been installed the wrong way. The housing is offset. Get it wrong and it would put a lot of stress on that centre hanger bearing bush.
Aalbloshi
This. You can't tell an unbalanced wheel from looking at it, even if it rattles your teeth. You have no hope on a prop shaft
So basically The Shaft Turned out to be Good, the mechanic Replaced the shaft Support with the genuine one, And I’ve been driving the car for 5 days No Vibration and All seems good now will give u more Update next week
Aalbloshi
Are you sure the problem is the drive shaft centre bearing. Sounds more like a missing centering bush in the yoke is causing the rubber dohnut coupling to flog out in short order. My mechanic told me the rubber dohnut coupling is the same as used on BMW. I have never heard of the Holden driveshaft centre bearing being the same as a BMW unit.
Hey brother, Do u know which BMW coupling is Compatible with the WL?
DavesSV6Tonner
Australia
VZ S V6 Cab & Chassis
Sorry no, my mechanic only said the rubber doughnut coupling on my VZ 1 Tonner is the same as those used by BMW. Didn't state specific models and I didn't ask.
Fu Manchu
WA.
If you go back to post nine, there’s a link that lays that out for you.
HSV126
Briggs & Stratton
Question, as a former parts interpreter, If the Holden and BMW use the same part, I can't understand why you would you want to buy the one that has 5x the markup rather than buying one from an OEM supplier like mackay?
Immortality
Staff member
Sth Auck, NZ
Maybe because where the OP is located BMW parts are easier to source than Holden/GM?
