ben315vz
Donating Member
- May 11, 2011
- 1,466
- 22
- 38
- Age
- 32
- Location
- Tamborine Mountain, QLD
- '05 Holden VZ Calais V8
Hey Ben, building a box and building a sub box are two totally different things. If your ready for it, good on ya!
List of materials are....
3/4" MDF between 1-2 sheets depending on your enclosure
Liquid nails
1 1/2" wood screws for MDF
Silicone
Spray adhesive
Speaker terminal plate
Pre-drill all your screw holes or the MDF will just split like a ..... banana
As well as screwing every panel down... use a bead of liquid nails for good measure.
Every join must be siliconed internally.... and there is a trick to that also!
Start with the front of the box, then glue, screw and silicone the sides on. So the only panel left is the back.
Then glue and screw the rear panel on.
Flip the box and cut out the sub hole use a jigsaw. (usually there is a cardboard template on the box or in the box. Make sure you use the smaller of the two, otherwise that puppy drops right through!)
Once you have cut that hole, vacuum out the box and then you can easily silicone the back panel through the sub holes.
If you go the path of a vented enclosure, I spray matt black into the sides of the vent to cover the raw wood.
Also, don't forget to drill the hole for the speaker terminal (don't laugh, you'll be surprised at how many remember after carpeting...
But seriously mate, there is so much to consider to do it properly but if someone says they want too.... then you ask as many questions as you want you will find many of us here have the answers.
That is exactly the information that I am after, thanks very much for taking the time to write that up
That picture I uploaded, that's what I want to do. Now the only problem is that the VS has a weird shaped boot, but I am still willing to give it a go.
Thanks for all the help though guys, I think I have enough now to get started at least haha.
