91SS
- Oct 31, 2017
- 205
- 77
- 28
- Location
- Sydney
- Holden Commodore VNSS 1991
Really appreciate the tips and diagrams. Cheers.Found a Holden Publication img.
This shows the 'toothed disc' /interruptor ring
Only 1 circlip from memory
Looking at diagram the interruptor ring is item4 listed as toothed disc.
Thinking if this indeed is fault it may be doable in car perhaps lying on manifold or on a step from drivers side.
Still can't see roll pin in diagram on toothed disk/interruptor ring?
Is pin? punched out from side.
If interruptor ring is culprit can this part be obtained? Or it it a case of raiding a SH unit or replacing whole distributor?
I've owned car ince 1994 with 185kms......done 3 cap and rotors dizzy and parts are are original and GMH..Nobody else has touched the distributor.
Jaycar unit looks good. Would probably go with that. Other parts come with plate and are about $125..
Started it again tonight cold ran for 15 seconds smoothly and died.
Just want to make sure module is okay.
Many thanks.
