Check engine light turning on - Engine running lean
Dozza
34
Australia
VY 2004
Hi guys,
The check engine light has been coming up on my 2010 VE SS. I had it serviced the other day and apparently it is running lean "bank 1 bank 2". They have told me it needs to go to an auto electrician for diagnosis as he thinks it could be a damaged O2 sensor.
Is this possible?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Could be tired O2 sensors, how many kms has the SS done?
krusing
Melbourne, Bayside
Hmm, How can you have it serviced,
And all of sudden the O2 Sensor activates the MIL,
What else the mechanic do ?
TAS1981
Get a Tech 2 read. Could be a number of things.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Did you have anything done to the car before the engine light started coming on?
syked
Donating Member
2011 WM Caprice
You need to check live data on the front O2 sensors...if the mV needs to be fluctuating between high and low.
Also it will be worthwhile to check spark plugs and get an idea what's happening based on them.
