greenbeam said:
Hey Steve,
It sounds like you have the best recent experience of fitting a Holden factory system. I've been pricing around and have received some conflicting stories, so can you answer some questions for me please.
1. LCD integration - just what does and doesn't work. Eg The fuel low display and sound - does it also work for the gas? And do the fuel economy & distance to empty displays also work for gas?
2. I've been told the factory kit switches back to petrol under load, so in effect you still use petrol, only less than before. One reason given is to keep the lubricating effect, but another guy told me it is stop backfiring, which the IMPCO system is prone to.
3. On the conversion that I saw (non factory), the petrol cap was cut down to about one thread so it would clear the gas filler. What do they do on the factory kit? I can't believe they would just cat down the cap, but do they fit a different petrol cap, or it the gas filler fitted so it clears the petrol cap?
I hope you dont mind answering this - possibly worth making it a sticky?
Cheers,
Paul.
Hi Paul,
Some answers for you.
1. Low fuel & economy Lts/100km, with sound and a flashing LPG gas tank Icon appear on the LCD display. All the same as per petrol, but with an LPG tank icon instead of the petrol icon.
2. You are correct under "Heavy" engine load, (eg towing or really putting the boot in etc.) a small amount of fuel is injected to boost power. Normal driving uses gas only. It doesn't use petrol for cold starting and then switch to lpg like the toyota system. We have had some cold mornings and the car starts fine on gas only. It can obviously be started on petrol if your prefer, simply by the push of the button.
3. To fit the gas nozzle above the existing petrol cap requires a smaller shorter petrol cap. The installers supplied a smaller cap (not sure if Holden supplied it in the kit). The installer made a point of telling me it was a shorter petrol cap when I picked the car up.
He also said that although back fires are rare, they can be avoided as they happen on start up. Simply hold the starter a fraction longer when starting from gas to be sure the engine has started.
I have just about finshed the first tank of lpg, (I am going to run it out to see how far it goes) The dash is has beeped and warned LPG low with a flashing LPG icon, and 8km distance till empty. I've currently done 387kms on this first tank of gas and the LCD says 12.4lts/100. Not sure how accurate that is but the whole kit all seems well integrated. If you have and executive, with Mr Howards $2000, Why wouldn't you install the genuine Holden kit?
I'll Keep you posted...:thumbsup:
cheers
Steve
