Coolant leak VE SV6 2009
Gazmaz
55
VE SV6
Hi All,
My 2009 VE SV6 is leaking coolant from the top front of the motor.
Coolant stains are all over the front of the motor and in the sump cover.
I have topped up the coolant a number of times. The coolant reservoir is
always dry when I check. The car is not running hot.
Any suggestion on what it might be and cost to repair.
I'm guessing a water pump related issue.
The car has done 200K KM's.
Thanks,
Gary
DAJOKER
Adelaide, SA
VE SV6 II Wagon
Checked the oil? If it looks like ice coffee,coolant and oil are mixing because of a blown head gasket.
Fu Manchu
WA.
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
What Fu Manchu posted will be your issue, very common to be miss diagnosed and also over looked. Fairly cheap to do yourself
greenacc
Searching for the billion
VE Berlina
As above, replace the two rubber seals and your problem will most likely be solved. They cost about $25 depending where you go.
Gazmaz
55
VE SV6
Hey Dajoker,
Oil looks normal.
Leak looks to be at the same location as per Fu Manchu's video. (great video dude. thanks..)
I Will have a crack at replacing the seals as per the advise from Fu Manchu and greenac.
I will update this post when done.
Gary
Gazmaz
55
VE SV6
Is the same gasket set used in my SV6 engine
Model: VE 2009 SV6 SIDI
Engine type: 3.6L alloytec V6 LLT
My engine setup is different to the one in the video posted by Fu Manchu
greenacc
VE Berlina
Check one of the good websites you plug your rego number in to look at the parts for your car. I'm guessing it's the same.
syked
Donating Member
2011 WM Caprice
I don't believe the LLT have a a removable coolant filler neck like the one in the video
I'll double check on my car though
syked
Donating Member
2011 WM Caprice
Yeah looks like the LLT also has a removable filler neck. I'm guessing the gaskets would be the same
