I noticed the light brown sludge under radiator cap. Not sure how long it was like that. The car runs fine, the guages are normal. So it was only a random check under the radiator cap (because we usually fill the reservoir) and we saw the gunk.
Oil in the coolant?. It was a very thin oil in the coolant. Checked engine oil. It was OK, so we changed filter and Oil.
So the other oil is the Auto Transmission Fluid. Wasn't sure how that can get into the radiator, but someone on this forum suggested the Auto transmission pumps ATF into a brass tank that is built into the radiator. So I bypassed the radiator and used an external auto transmission cooler. The ATF doesn't go near the radiator now. I also replaced the auto transmission filter and fluid, which looked OK, no coolant in the auto pan. I ran the engine and watched the (now unused) connection points on the radiator and I noticed leaking fluid so it seems that was the problem. I just need a new radiator. I need to drive the car around so I blocked these connection points on the radiator and everything seems good now. I flushed the sludge out of the radiator. A week later, I noticed a bit of sludge in radiator. I ran tap water through the engine and radiator again to clean it out. Then a suggestion that the heater core might be contaminated from before, so I opened the heater while I flushed it again.
A week later I still notice a little bit of gunk in the radiator.
Why isn't it clean?
I read the thread about the inlet manifold gasket. So if it isn't one thing then it must be the other.
Or is it going to be both?
So if it isn't
