cooling system, overheating, i've replaced almost everything Help!!
Miss_BB
Hervey Bay
VX Commodore
Hi everyone. I posted earlier about my VS running hot. It used to sit at about the 2nd the 3rd notch on the temp guage and it started running at the 5th to 6th notch and higher. I could drive for about 20 min before it got to that point.
Anyway, Over the past week and a half i have replaced the thermostat, the wiring for the fan, the temp sensor, the coolant temp sensor, the waterpump and backflushed the radiator and put new coolant through it. Its still running hot. In fact if anything it seems to be running hotter now than ever. The temp on my half hour school run this morning ran to one notch below H.
Fan runs on both speeds and kicks in and out, coolant not spurting out anywhere, no leaks, Hoses look brand new. Radiator looked fairly new and while the flush did get some stuff out it was minimal.
Am i missing something?
tezza
VX SS
Was the coolant system bled of air, is it using any water or is any water getting into the oil?
I would also see if you can check to see if the guage is working correctly.
Brett_jjj
Tamworth NSW
vs commodore
Check out the bottom radiator hose whilst someone is reving the engine a bit,even though the hose may look fairly new, they can get weak over time,especially the cheaper brand radiator hoses,and they can suck in and collapse from the suction of the water pump,this then blocks the coolant flow into the engine.Some bottom radiator hoses have a metal spring going through them to stop them from collapsing in.Other than this, Id probably also consider fitting a new radiator if the old one is a few years old.On ebay,they are only $80 or thereabouts,which is a pretty good price for a brand new radiator delivered to your door.The old one might have a few blocked tubes that backflushing cant unblock.Then,if the new radiator doesnt make any difference, Id consider taking it to a radiator specialist or a mechanics and getting them to do a cooling system pressure test and a compression test on the engine,these tests will confirm if theres any problems with any of the engines gaskets or cooling system including the the head or inlet manifold gaskets etc.These tests are cheap to get done and are the only real way of telling the condition of the cooling system and gaskets etc.Also check out the A/C condenser,this is the radiator looking thing that sits in front of the actual radiator for the engine,because it sits in front of the radiator,it cops all the bugs ,dirt and crap,which slowly blocks it up over time.You can remove the radiator and then blow the condenser out backwards with a good strong water or compressed air stream.
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
Stupid question I know, but it's been done before - has the thermostat been installed wrong way around - this means the wax pellet that senses heat is on the cool side and not the hot side. This results in a very slow acting thermostat...it eventually opens but not till the heat has 'leaked' thru the thermostat body. As an example of how easy this is to do, I just checked a brand new thermostat in my shed - on the wax pellet side it is marked "to rad" with a small arrow pointing up. The problem with this is that if you install it with the "to rad" on the radiator side (cold side) you have done it wrong....it's the other side that goes to the radiator.
This is not uncommon even with mechs who know their business.
Miss_BB
Hervey Bay
VX Commodore
Cooling system was pressure tested last monday. All good or so the radiator doctor said. Hasn't been done since as we have been replacing parts ourselves to save money. Radiators on ebay are only $100 if your looking at the older commodores. I have a series 2 so its more closer to $200. Hence the reason why we back flushed it first.
Oil is good, we are not running through coolant, level has stayed the same pretty much the whole time. Then again coolant has been replaced several times over the last few weeks as everythings been replaced. Everytime somethings been done we've used the bleed valve to get rid of any air. We've checked all the hoses while the engine has been running, all hoses are good.
I guess its time to just bite the bullet and buy a new radiator. Just over the money pit you know.
Brett_jjj
Tamworth NSW
vs commodore
The series 2 VS V6 radiators with the screw on transmission cooler fittings are only around $100 still. Check this one out.
---Holden Commodore Radiator VS 3.8L V6 7/1996-98 SERIES 2 (eBay item 200533862067 end time 20-Mar-11 10:21:40 AEDST) : Cars, Bikes, Boats---
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
Here is a cheaper one with the screw on fittings for $85 DELIVERED. Holden VN-VP-VR-VS Commodore V6 Radiator NEW #1 Quality (eBay item 260498876974 end time 24-Mar-11 10:18:33 AEDST) : Cars, Bikes, Boats
and check that thermostat!
Miss_BB
Hervey Bay
VX Commodore
Thank you for this. I will check the thermostat, although i think even if the guy did install it wrong i could never get him to admit it you know. This guy is the one who swore to me that he was positive it wouldn't be the radiator, now look where i am....
I'll buy the new radiator too. $85 is doable but not the $250 they are charging up here. Just have to baby my car until it gets here. Sad to say i think i may need to get me a new car. Thinking about it as much as i love them my history with commodores means they don't love me.
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
Buying another car sometimes may seem easier, but you have to sell your old one for which you need a RWC (more$$$) and find one to buy at the right price. Remember that not many people sell a car that is 100% and you may be buying their problems. VS Commodores are pretty good value for money compared to other makes and have the room you need. Better the devil you know.......
godatfourdigital
EH Holden, VS Ute
what about the fan speed relays...
when i got my vs ute, it would sit on the 2 temp bar cruising, but under or about 60kms it would go up to half way...
driven a few vs's before, i know the temp should pretty much always sit on the 2-3 bar...
i did all that you have done, replaced the lot... no fix, in the end, the low speed on the fan wasn't kicking in., replaced the relay, all sweet, normally sits on the 2nd bar, hasn't moved past the 3rd bar since i fixed it.
