Devuk
- Nov 23, 2016
- 6
- 0
- 1
- Age
- 29
- Location
- New Zealand
- 3.8 VT
In my ecotec 3.8 v6 2000 commodore, the fault codes are suddenly:
Idle speed error, Cam angle sensor (no signal), and Low speed fan fault!
I replaced the cam angle sensor upon getting these fault codes. No change
previously diagnosing why it wouldn't start, the fault codes were standard operational order
BCM replaced and new key coded, car has spark. starter motor is fine, battery is fine. red light comes off mode when you put the key on reds. Have cleaned gunk and sanded the contacts on the ignition switch to try. Key makes contact with ring around barrel
Usually when you turn the key nothing happens, complete turn off then back on again cranks for a little bit. turn all way off then back on again etc same deal, 1 in 3 chance of working and cranks weakly, compared to start motor bypass which cranks immediately and powerfully.
Bypassing the starter motor gives a clean crank and is so close to start but just DOESN'T. It's like it fires for a second then stops, if i leave starter bypassed it will just crank and crank, have tried giving it gas. have cleaned and sanded the corrosion in the ignition switch.
