Vx LS hard to start
gen5
55
Sa
Vx ls
Hi thanks for the add.i have vs LS v8 hard to start on the 1st start key off then on it starts I've spent hours on it as iam a motor mechanic. I've had security turn off different pcm what I've found is intermittent injection on 1st start is the problem no codes cam /crank coralation ok checked with scope all powers and earth checked it's driving me crazy any help would be appreciated thanks in advance
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Slightly lazy fuel system?
Jezza
Now with LS1 power
South Australia
WH Statesman International
Have you replaced the cam sensor at all recently?
I had a weird starting issue that ended up being a faulty aftermarket cam sensor that caused issues on initial start but then fired up on 2nd start. Replaced it with a genuine GM sensor and that fixed it.
Forcedvp
VT HSV XU8, FORD TERRORIST
Try full throttle on first start next time. Just to see if its a possible leaky injector issue or tps
gen5
55
Sa
Vx ls
Hi jezza yes it just had 1 replaced as it had a cam sensor code before iam not doing the work on it it's at work place so not sure how it was starting before but came it with a hot starting problems thanks for feed back think I get a gm 1 and replace it
st3r3otyp3
Donating Member
VX HSV VX SS
Hi, I've got this exact problem, is the OP still around, I'm guessing he might of fixed it.
lout
60
Langwarrin Victoria
faulty check valve in fuel pump?
try turning to reds for 5 seconds
then turn off
then attempt to start
try following this for a week as a diagnosis trial
st3r3otyp3
Donating Member
VX HSV VX SS
then turn off
Hi, question on that would be it's passed a pressure test, if it was faulty would it still pass?
Just have to add sometimes it will start first go hot or cold.
lout
60
Langwarrin Victoria
will still pass a pressure test
if you were to connect your pressure gauge and leave it connected
it should hold pressure for a week or so
you will probably find yours drops over 5-10 hours
so when you go to start in the morning there is no fuel pressure
until pump has run for a few seconds
check valve can be intermittent
same deal as you, i am mechanic/auto elec and had this on my wifes car
took months to diagnose as also had to translate from wife speak to technical speak
