Dash saying door is open but it’s closed
Fu Manchu
WA.
I’ll bet it’s a door actuator
thScythe
24
Saudi
2008 Caprice
I changed the driver and passenger door actuators and the light still isn’t gone. I’m not sure why the rear ones would be bad as the rear doors barely get used.
krusing
Melbourne, Bayside
Check the Loom between the Door pillar and the Door, (On the Drivers Door)
(Cables in the rubber transfer boot)
krusing
Melbourne, Bayside
thScythe
24
Saudi
2008 Caprice
I’m in Saudi so we are LHD so would it be on our drivers door?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Fu Manchu
WA.
You access the loom from the outside from memory. Door open, use a nylon trim tool to remove the boot seal on the body side carefully annnnnd I don’t remember how the plug comes away from there. It does though.
Something unclips and you can pull the loom out a bit to unplug it.
rjp
WM Caprice with LS3
A very long shot....
Do the overseas versions of the Commodore check if the boot and or fuel cap are open? I had an old NL Fairlane and it would show if these were open too.
Just a thought.
thScythe
24
Saudi
2008 Caprice
Just a thought.
I have never had an open fuel cap or trunk send a light. Mine doesn’t even show when the passenger seatbelt isn’t in.
