Dead VG Ute
Pete O
68
Meringandan
1990 VG ute
Ok so my 3.8 Buick has been playing up, not idling, hard to start etc. my first thought was CAS so I ordered one. Got busy this morning & installed a new CAS, timing cover seal ( while the Harmonic balancer was off) an IAC, (just in case) & I cleaned the throttle body to as new again. I hit the key expecting the purr of the V6, but nothing, It wound & wound & flatly refuses to even try to fire! I even put another coil pack on in case it was dodgy but still nothing. I checked the engine bay main fuse & changed the relays but still nothing. I did spray a bit of degreaser in the intake to clean the carbon off but that shouldn’t make it refuse to start. It smells fuelly after winding it over, like it’s flooded.
So anyone wanna have a stab at what’s going on here???
Cheers.........Pete!
losh1971
North Tas
VE Series I SS Ute
Series 1 or series 2, series 1 you need to set the air gap.
Pete O
68
Meringandan
1990 VG ute
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Reconnect the CAS? All the connectors and hoses to the TB?
Pete O
68
Meringandan
1990 VG ute
Yep done all that & double checked it all as well. I’ve been over everything I can think of & i’m out of ideas. The next thing I may have to do is the air gap if it is a series 1 as suggested by losh1971.
losh1971
North Tas
VE Series I SS Ute
Is there adjustment in the CAS? Later models don't have adjustment and just bolt in.
Pete O
68
Meringandan
1990 VG ute
Yes you can adjust it side to side for the gap between the cas & the reluctor fins but there is not a lot in it. Maybe it has to be a very specific gap but I don’t know for sure.
losh1971
North Tas
VE Series I SS Ute
Ok then yes then the gap does need to be spot on.
