Design for my air intake. Any good?
peckzz
35
nsw
vr series 2 v6
peckzz- Im going to do somthing sort of like yours, but instead of the pipe, im going to modify the otr cai, and some form of heat proofing on the inside of the box..
also how did u move the washer bottle? or did u just get rid of it all together?
Thanks
yea removed it compltely right, and got one out of a vn-vp, it sits around the top drivers side high hat, just near the brake booster, i will take some pics in the sun today so you can see, but have not got the new washer bottle in as of yet.
took it for a drive last nite, i can definatly GAURENTEE you (bad spelling but oh well) that it has alot more power with the 2 inductions instead of the 1, knocked half a second of 0-100 times
Jamie-b
VS ute
Ok thanks mate,
when you put the new bottle up, could you please write a quick DIY, or even just give me some tips, if its not completly straight forward...
Do i need a new water pump motor or anything when i do this?
Thanks
Edit:
it says HERE that the vn-vp washer bottles wont fit..
the VS has different strut tops so the Vn washer bottle wont fit.
peckzz
35
nsw
vr series 2 v6
Ok thanks mate,
Thanks
Edit:
well seems i have to do some searching on this, my mate has a vn out the back of his house, i will see if it will fit, if not i will have to modify some where for it to go, i will keep you posted
EDIT: i just had a read through that forum, and something triggered my mind, the only reason you have to remove the washer box is because of the stupid bloody neck on it to fill it up right, so what if we cut the neck to about 1 inch off the top of the bottle, then get a peace of flexible plastic tubing as thick as the washer bottle neck so it will slide on top with a clamp around it? because its not taking serious pressure and heat, that way you could have it coming out where ever you want, and for a lid, cut the top of the washer bottle off about a inch, then do the same as connecting it to the bottle, just chuck a clamp on it, i might actually do this today and post pictures tonight of it, might seem a bit dodgy but hell, we all gotta live by a budget and some are tighter than others, like mine for instance haha
speed_freak
33
VS Executive 3.8 Eco
ok this is my finished product
yZoH
//There Ain't No Rest For The Wicked...
S/E Subs, Melb
www.lolwut.com
(0.o')
speed_freak
33
haha i regret painting it yellow now. it needs a few more coats of paint. ill do it when i can be bothered, its too bloody hot!
speed_freak
33
tested going over a curb this morning. it doesnt hit. it looks lower in the pictures than in real life, i think i had the camera on an angle. just gotta get some flyscreen over the tops of the vents and it will be done
speed_freak
33
theres a definate difference above 3-3.5k it really starts to pull much harder. also noticed that engine tempreature is slightly lower than before. sits at about 1/5th 1/6th whilst driving. all in all its not too bad considering the cost.
all up it was
1m 75mm PVC Pipe - $6.95
3x 90deg bends - $9.30
1x 90deg tee - $4.50
1x dropper outlet - $6.28
1x straight joiner - $3.28
- $30.31 for the CAI
1.5m Neoprene rubber - $22.75
aluminium sheeting - cant find receipt but it was like $10 or something
all up was about $60.00 in parts to build the box and the cai. not too shabby at all.
