adi91
- May 10, 2013
- 60
- 3
- 8
- Location
- Riyadh,Saudi Arabia
- VZ
just a tip, when you remove the 2 plasic covers, you will see the coil pacs, try not to get eny water pressure on them, I washed mine the other week, and got water in no5 started to run sick, with a drive train fault ended up changing plugs, fuel injectors ,all good now
WaoOw....gee thnx for the heads up ma8 (y) ....btw can you plz point out the coil packs?
Btw A big thnx once again
chev badged, leave it as is to hide your shame.
Thnx for looking at the badge and not the post :rofl2:
Cover the alternator, air inlet and avoid applying direct jets of high pressure water onto any connectors (electrical/mechanical). Take your time and if the de-greaser is any good and does the job you could probably get away with just a standard/low pressure garden hose.
Thnx...will so that fou shou...Amma be using Megiuars APC (All Purpose Cleaner), it can be diluted according to the need so that's gonna be helpful for sure
First I will say that is one dust ass engine bay!
Secondly, I detail engine bays all the time and the only thing I ever cover is exposed air filters, or electronics from older cars. Plastic bags work well.
Modern engines are pretty easy to clean, the only thing to remember is not to spray a stream of water near electrical parts or air intakes.
This is what I do after I make sure the engine is cold, or only slightly warm. Never on a hot engine.
What I do is first use a pressure washer and lightly rinse it all down without directly spraying anything. I spray a light degreaser/Soap/Car wash all over the engine and bay, use a bunch of different brushes to agitate the dirt then rinse it off with the pressure washer, once again not directly spraying anything.
Afterwards I also like to use either compressed air or warm filtered air to dry the engine and bay. Makes it so much easier to get water out of all the crevices.
Then just start it up to dry off any extra water.
I also only use a pressure washer and don't use a regular hose as it will spray too much water around the place and could potentially cause electrical shorts.
OUh yeaa ...it has become nasty over the years :spew:
Btw thnx for all the info...will keep in mind everything you said btw what about the "coil packs" as said by the other ma8 & alternator? :\
The Number 3 hole has a bolt way down there same as the hole back far right. If you take those 2 bolts and the 4 large ones in the middle ( Leave the other 2 alone )you can take the intake off without needing to change the intake gaskets.
:idea3: MYSTERY...solved thnx for tht
When I did mine I just used most of a can of degreaser, then washed it off with the garden hose. It'd never been cleaned before and even the really dirty bits come good. I also used tyre shine on the radiator and engine covers, and other spots, came up really well. Only thing I covered was the air intake, had no problems after.
I'm putting 25mm manifold insulators on soon and so I've removed the engine covers and was wondering about getting anything too wet in there. After reading this it doesn't look like ive got anything to worry about.
Yeas...thats true u need to have a good de-greaser for sure, am gonna be using Megiuars APC (All Purpose Cleaner), it can be diluted according to the need so that's gonna be helpful for sure...hey ma8 me too :yahoo: ...actually I ordered a MACE CAI and 12mm manifold insulators so am gonna be installing those after am done with the engine bay
