vc commodore
- Jun 18, 2014
- 10,729
- 12,635
- 113
- Location
- Like the Leyland Brothers
- VC, VH and VY
The Holden Commodore is designed to use a hub centric wheel. So use it. There are examples of after market wheels that have failed and come off the vehicles because the wheel wasn't fitted using a the proper size hub ring.
You Aussies call us kiwi's dodgy and yet you 2 guys that seem to work in the trade are recommending the most dodgy of methods for something that is fundamental to a vehicle driving safely on the road.
The hub centric wheel was only designed, to eliminate balance issues that can arise, due to the unsprung weight difference between the early model cars and later model cars.
A wheel will only come off, if the wheel nuts aren't tightened correctly and in the correct order....Nothing to do with a hub ring. If it had something to do with hub rings, why did it take decades to introduce them? Why do 2,000 + HP drag cars run axles, that have no drum boss....No drum boss, means wheels are held on by wheel nuts alone and nothing else.
EDIT, I stuffed up....Wheels can come off, when aftermarket wheels are fitted with hub rings, and the spare is a factory wheel....Especially when people fail to notice them and forget to remove them.
Nothing dodgy about a die grinder buddy.....It's identical to a lathe....In the wrong hands, things turn to crap really quick...
