eco vs power
Jxfwsf
Aus
commodore
makes no difference to the line pressure as that is regulated by the boost valve, the power button sole purpose is to change maps for the shift points for a more aggressive change, more responsive feel
Line pressure is also controlled by the force motor which is pcm controlled for the 4l60e (th 700r4/4l60 relied on the throttle valve to control the line pressure, the harder you pushed the pedal the more the line pressure increased, it's not solely controlled by the boost valve).
VR BPLZ
VS BWPJ
VSBWPJ -1.jpg VSBWPJ -2.jpg eco with pwr table pasted over, red indicates changed value
VT CXWL
I do not recommend changing these values unless you know what you are doing, stuffing up will result in a buggered trans
666vt
[ no style ]
nsw
vt executive 3.8
ok thanks for the info guys :beer chug:
666vt
[ no style ]
nsw
vt executive 3.8
also, new question off topic:
coilovers for vx?
would they be good for towing?
that way i can get rims, and make it look good by slamming it, then raising it for towing.
hope so.
Jonah 101
Undefined
Rotorua
R32 Skyline
I towed a VP commodore today for several hours, Up some pretty big hills too. I used the PWR mode the whole way. Used just as much petrol if not less than I usually do.
This was cruising between 90 - 100kmph
Jxfwsf
Aus
commodore
you drive with a lead foot normally then.
Delish-VY
Banned
Originally - Eastern Suburbs - Melbourne, Currentl
2003 VY S pack
+1, but that being said....PWR mode on when doing 90-100 isn't going to make as much difference as if he had PWR mode on and was accelerating heavily from 0-60 frequently.
Jonah 101
Undefined
Rotorua
R32 Skyline
I also normal travel half an hour total a day up a windy gravel road to my house, top speed 30kmph... When i leave my house this means it takes 20mins before my car reaches temp because I am driving very slowly down hill, I hardly touch the accelerator.
also when towing a large load, its getting you up to speed that's difficult, holding that speed is no problem, that is until you find a hill haha.
Immortality
Staff member
Sth Auck, NZ
LOL
As mentioned earlier, It alters the shift points and converter lock/unlock as well as bumping up the line pressures a little.
I've had the missus ecotec in powermode for years. I hate it when in eco mode and it's lugging around in OD at 50km/h and you need to give it heaps of gas to kick it down.
To be honest, when I went back to economy mode it used more gas, now i've retuned it so that economy mode also holds 3rd longer and it's much nicer to drive, also don't need to give it as much gas to kick down a gear or unlock the converter when cruising so basically the engine doesn't labour like it does in the standard economy mode.
The stock transmission shift points really suck.
BTW, using an auto box manually won't #### it at all. In fact it is recommended to shift it manually under certain circumstances. The tune has settings to stop you abusing the trans to much, you can slip gear selector into 1 at 100km's if you like but the box won't kick down etc
Dylan_11
newcastle
vs bt1 commodore
i have a full manualised auto picked it up cheap off a mate. leave the pwr button on round town like JXW said it lags the car really bad. will slip your torque converter. but everyone has a difference of opinion. go with wat you feel works best for you and you like. btw get a shiftkit and a tune. ull b alot happier =)
