Drilling L67 Crank for Manual Dowel Pins
IF the flywheel you have has the dowel holes already in it.
Then:
Buy the correct dowels.
Buy new T5 crank to flywheel bolts.
Buy a new 1/8" drill bit.
Buy a new 5/16" drill bit.
Buy a Transfer Pin Punch set -
Page Not Responding ... 0735697159
Bolt the flywheel up loosely at first, when all bolts are in the
correct position (remember there is one
offset bolt hole) find the centre of the hole size clearance on the bolt sides. Do this by rocking the flywheel back & forth, once in the centre lock the flywheel bolts up.
Use the correct size Transfer pin punch to mark the centre down the dowel hole of the flywheel, ( I used a 5/16" as I didn't have a 8mm punch).
Work out the total depth needed to be drilled for the dowels (don't over drill the depth cause you may find you have weakened the crank flange).
Use the new 1/8" drill as a pilot drill.
Follow up with the new 5/16" drill & drill to correct depth.
Remember it is only a noddy iron crank so wont be hard to drill.
Note: The dowels are 8mm but if you use a 8mm drill it will always drill slightly oversize & your 8mm dowels will be loose in the holes. Using the slightly smaller 5/16" drill size will give the tight fit required.
The dowels have a taper/chamfer on one end, this goes into the crank first.
Get organised with a brass drift to hit the dowels with ( don't use a hammer straight onto a hardened dowel pin).
Blow the swarf / waste metal out of the new holes. Follow up with some CRC type lube down the hole, but don't create a puddle in the bottom of the holes (we don't want hydraulic lock when fitting the dowel pins).
Put the dowel pins in the freezer for about 15 minutes to half hour.
When ready, do one at a time,
quickly. Insert the dowel straight out of the freezer into the hole and drive it in with a hammer & brass drift till level with the flywheel bolt flange thickness.
Another note: When drilling the holes in situ get a couple of friends with good eyes to eyeball the drill for square to the crank flange while you are doing it. It will be hard to fit all your heads in there, but you don't want to drill off at an angle.
Good luck.
Oh btw, some will say it is not necessary. It's your choice.
Deek
