Does anyone know the flywheel part numbers for the VS Ecotec or how are they identifiable vissually?
I purchased a series 2, 8 bolt flywheel but do not know if it is Vr series 2 or VS series 2 etc.
how can you tell the difference by looking at them?
I don't really want to fit the whole thing in and find out that the boat vibrates like crazy
My flywheel part number is 92061852 if that helps
Have just stripped the motor down for the rebuild and will hopefull be fitting it in over the next few weeks
Also curious as to who in the South East of Melb can do a cam shaft grind, and at what sort of cost, Looking for low down grunt and rpm between 1000 upto about 4800rpm for it to be more boat freindly
Cheers Andy
hillboy89 said:Hey there mate,
First of all very interesting project you got going there! will be sure to keep an eye on the progress of it and im sure my old man would be more than interesting in it.
I still haven't managed to get my hand on the proper flywheel even tho the one i brought was that apparently was one but wasn't, but i could almost positively say that your in luck with the flywheel you have. Does not look like any of the Buick flywheel's iv seen as they all look similar to my one. Also the part number like you said is so close.. Although on that note i am not sure what the get-rag flywheel's are meant to look like as they were used in the series 2 vs's.
But, i was told no matter what flywheel balance i had to get it 'mirror balanced' to my vs automatic flex-plate.. im not sure if the motor you have, had one on it or was originally a manual but if it did, you'd be better off making sure and getting that done anyway.
Hope this half helps, Goodluck with the project and ill try assist with anything else you need.
p.s maybe copy this onto the post to help others? ..If it makes sense, bit tired
If you are going to cool this motor with see water make sure you got plenty of electrolysis blocks fitted.
