mitch85
Hi guys, im new here so go easy on me! :kiss:
I've got a '97 VS and she has a few issues starting hot. I've already replaced the alternator and starter motor (brand new from Repco).
When the new starter went in, it worked fine for about a month and now its starting to become hard to start again when hot. Cold starting is fine.
I am wondering if you guys know of, or have had the same problems and if you've been able to fix it. Being a starter is the obvious gremlin, but would there be something else that is causing the starter headaches? Or maybe Repco just sold me a dud. Anyway, if there are any problem solving tips or ways I could check to see if it is the starter or maybe something else, that'd be awesome.
Thanks guys!
PROBLEM SOLVED:
Ok, so I've seemed to have fixed the problem.
I checked everything around the starting system, wires, earths etc etc. mostly what you guys have recommended. I didn't really find any issues. Again, I checked the battery - full charge, amps etc etc. Heres the thing: After buying a battery booster for my work van, I just so happened to have had it in the car when it refused to start whilst I was filling up with juice. :idea3: Thinking what the hell, I tried using the jump starter. Hey presto! It fired into life quite quickly. So, I again checked the battery when I got home, everything was normal. I pulled the battery out (it didn't have a colour indicator) and went down to the battery place who took a look at it. Well, she was a dud. Anyway, $155 lighter and a new battery....good as gold! :rockon:
What seemed a perfectly good, 6 month old battery turned out to be a p.o.s. If anyone has the same problem, try using a different battery. There are always duds out there!
Thanks guys!
PROBLEM SOLVED:
