05red vz
- Oct 21, 2017
- 30
- 7
- 8
- Age
- 56
- Location
- cornubia
- vz ute
ok have a vy v8 one tonne ute, have just installed 2 thermos/oil coolers trans and engine oil cool . i had them wired up to the 2 15 amp ignition fuses located where the fuse box is under bonnet. both with there separate relays and auto circuit braker fuses.
ok so heres what happened , drove the car 2 klm to get fuel , on the way back home stopped at by bros place and the Auto cooler fan was running ( car still running ) all good thinking the temp sender now has cut in and now cooling auto , great . turned off the engine spent a little time with my bro. get back into the car wont start , no ign lights nothing interior lights wrk. so when i tried to crank it over and with no ign lights etc the indicators flashed on several times , just like when you put on your hazzard lights. thinking this is weird checked every fuse and every braker all good . disconnect the battery wait 10 min reconnect indicators flash several time again, but still nothing . so tow the car home very short distance from my bros to mine .
checked the key fob 3 volts battery is fine , check the car battery 13.8 volts new in dec all good there . is it possible something in the steering column area, electrical to do with the key is the issue . please if you have had a problem like this before please post up what you did
Auto lec is the last resort . have posted pic of how i wired the fans , 86 on relays goes to both 15 amp ign wires in the fuse box located under bonnet cheers
