Evoke help
Leeway
21
Clubsport
Hey team ! :)
Just wondering if anyone here knows if a vf1/2 bumper and grill would fit a vf evoke
Thanks
wetwork65
A wet business
VF SSV Wagon & VF SV6 Wagon
Hi Leeway - bit more information required.
Is it Evoke to Evoke?
Do you have series 1 Evoke?
Is the bumper you're considering from an Evoke or another model?
Leeway
21
Clubsport
Hoping to go from e-bike to normal vf1 bumper
Thanks !
gossie
Gold Coast.
VE International 3.6L
Yeah, bog n spray can I reckon.
kleanphil
G.C.
VF SS-V SII Sportwagon
Thanks !
I've seen similar getting around
Dreaded auto correct strikes again
Z31na
2013 VF Commodore Evoke
I dont think they changed anything on the Evoke between 1 to 2. Its not like there was much to change.
stooge
wa
Turbo Alpaca
it will fit your honda but the drls/fogs wont work, you will need to wire those up diy style
NJD-1992
VF-S2 SV6 Commodore
Edit: Assuming youre looking to swap the Evoke bumper to an S1 SS/SV6 style bumper
The Series 1 SS/SV6 Bumper will fit right over. I think however you may need different wheel arch liners, thought his maybe for Series 1 to Series 2 Conversions? You will need to replace all the grilles however, as they are different between the too. You'll also need the Chrome (Or Black) grille surrounds
As an alternate, consider doing an Evoke International conversion. You can keep the bumper, and just upgrade it to have the DRL's, gives it a MUCH better look for the least outlay. Id also go the additional set of painting the grill mesh in proper "Phantom Black" paint. They left it as unpainted plastic on Evokes which looks horrid after being in the elements.
wetwork65
A wet business
Not wanting to sound dismissive, but does the cost justify the outcome? I'm still confused as to what the required outcome is.
Evoke to SV6?
Evoke to Evoke?
The Clubsport in your profile to Evoke or SV6?
escooter to car?
  • Like
Reactions: Lex
