MickT
- May 10, 2009
- 57
- 0
- 0
- VY SS
Had the engine light pop on not long ago accompanied by a bad idle.
Plugged the laptop in and came up with those 2 codes (running lean bank 1 and 2)..most likely it would be a vacuum leak which i did find in the pcv pipe and also on the rear of the engine where the join is was split in half( very common).
Repaired it all myself plus cleaned and tested the MAF sensor(running well).
I unplugged the battery & reset the ECU...codes still there!!!
Anyone had the same issue or have any ideas of what next?
Cheers!
Cheers!
