Front Driver Door full of water?
Makedon78
46
2007 Holden Caprice WM Series - V8
I recently purchased 2007 Holden Caprice - V8 from Sydney. Lovely car and I'm really enjoying the V8 on country roads. Anyways, with the recent rains I just noticed today that my driver front door is full of water inside - I can hear it when opening and closing the door. When I wave it a bit of water comes but plenty remains inside. Any advice on:
-how to get the water out?
-shouldn't there be a drainage hole somewhere?
-are the seals on the door gone which is the reason why water is getting in?
Thank you in advance for your advice - it is much appreciated.
losh1971
North Tas
VE Series I SS Ute
Open the door and look underneath to see if it has drain holes. If it does poke a wire in the hole and unblock them.
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
Have a look under the door, there are usually 2 holes/slots where the water runs out but they do get full of crud over time.
You may have to remove the door trim to clean out the door inner.
Water just about always gets in through the top so don't worry about it too much.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
As the others have said, the drain holes are blocked.
Might be time to remove the door card and clean any of the crud out.
And check the outer weathershields to make sure they are working.
Makedon78
46
Thanks much mate - yeah, I pulled down the rubber seal from the bottom of the door and the drain holes were blocked with mud...all sorted - cheers!
