Getrag 5 Speed Gearbox Ticking
CaptainLeo
South Coast NSW
1997 VT Executive 5 Speed Manual
Hi all, I've done searches both on this site and Google and can't seem to find an answer to my particular problem.
I have a VT with a Getrag 5 speed box in it. Problem: it makes a ticking noise while driving. ONLY when driving. It starts at around 40km/h regardless of gear and will progressively get louder and faster as I speed up. Anyone have an idea on what this could be?
I don't wanna pay the tranny dude $1800 to do a rebuild if I can do the repairs myself; OR if I can tell him to only replace whats making this noise.
Any help will be greatly appreciated.
dirty hands
ipswich qld
magna
try drive shaft and donuts
exhaust leak maybe
centre support bearing if it has one
some like to break drive line bolts
check the engine mounts
CaptainLeo
South Coast NSW
Thanks fella's. Do these donuts have a technical name? I'd hate to walk into a parts supplier and ask for a donut....I'd feel a little bit silly :D
jacob112
australia
VT executive
sorta sounds like a headers/extractor leak? they normally make a ticking sorta chugging noise when they are leaking a fair bit.
CaptainLeo
South Coast NSW
@jacob112: if it were a header leak, I imagine id be able to hear the same ticking noise when revving in neutral yes? Either way I'll check all the bolts on the headers and make sure they're tight.
@EVY: any idea how costly a chipped/broken gear would be to replace?
dirty hands
ipswich qld
magna
drive shaft couplings might sound better than donuts
some shafts have universals but I havent seen any myself
EYY
VS Statesman
R.e. The exhaust leak, if it's not that bad you only really hear it when the engines under a bit of load.
A damaged gear was only a guess. Just a strange symptom, that's all.
Have you had a look underneath? Might be as simple as something rubbing on the vss wheel. Could also be the tailshaft centre bearing.
