Heater wont blow to screen
$enator
Dandenong , VIC
Vp Senator
hey guys,
i know its been coverd before but i cant bloody work out or get my heater to blow to screen, its stuck on feet which is probly default,
vp senator by the way, climate control
umm would/should be same climate control system as vr/vs would have
yeah change that little filter box thats located under the head unit, umm tested the butterfly thats located to the left of the headunit just beside the glovebox
and checked the vaccum hose from the ball, to the manifold through the firwall
then the one from the heater tap
still not workin
TrikkBen
I'm Back :D
SE, Vic
www.asroilpans.com
BNR32
Could be the vac connection from the unit itself. Pop the radio surround out and check.
Edit: I just saw climate control, my help may not be applicable as I am unfamiliar. Sorry.
mr calais 5.0
victoria
vy s 2003
The T peiece breaks in the motor bay near the fire wall.. It's at the back of the motor.. Mine broke and list the vacuum and would not change..
$enator
Dandenong , VIC
Vp Senator
thanks for all adivce
see how i go tommorow after work
just gonne buy big roll of hose and re wire it "outside" see if it works and replace the ones the need it
let yous know how i go
$enator
Dandenong , VIC
Vp Senator
worked everything out , thanks for the tips fellas, pumps that heat hard now ahaha
replaced all fitting to brass and clamped so should last bit longer
