Help me!
no1holdenfan
VX S PACK
hey guys. i have vt s pack its on LPG.
Yesterday my car **** itself majorly. It keeps back firing and i have little power. i can only reach 50kms/h. i called RACV and he reckons its some sort of gasket under the rocker cover. Any ideas?
alien
Tullamarine, Vic
03 VY Supercharged 3.8L
RACV really know nothing. The rocker cover gasket is only there to stop oil leaking out. If that gasket is stuffed all that happens is oil leaks out usually at the rear of the motor or drips onto your exhaust, which then makes your vehicle smell of burnt oil!
There could be a few things wrong, best thing would be to take it to a mechanic to get it checked out. Also does this happen on LPG and Petrol? Or is your vehicle only on LPG?
pablo
Donating member
Was a 1997 vt v6 wagon
Does the engine run OK on petrol?
fitz_vt
Pass Me A Wrench.....
Adelaide - South Side
VT Commodore SII Olympic Edition
what happens when you hit 50Km/h? does it not go anymore or does it die or .....
no1holdenfan
VX S PACK
It happens on both gas and petrol and when it hits 50k's it keeps driving but i cant accelerate ast 50kms
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
a backfire may have split the intake pipe or hit the maf wires ide check for a leak in the pipe first
no1holdenfan
VX S PACK
nope
nope no split in the pipes from what i can see. its backfiring straight back into the airbox now constantly and sounds like someone with emphasyma. its ****ed. im cut as. i want my falcon back.
any other suggestions??
ACEMonkey
1998 VT Acclaim S1
Did you change your spark plugs, swapped your spark leads or changed your coil pack recently? Just asking in case you have and the leads arent connected back properly in the correct sequence.
danja
Swerves for gay koalas
CBF 250 and a Levin ZR
Is the check engine light on? If so read the codes and that might point you in the right direction.
