daver00
I've got a 98 Berlina which for the last month has been giving me serious trouble. At first it stalled and had to be towed, traced the problem to the DFI module. A little wiggle of the connecting wires to the DFI was able to get it started, so we replaced the DFI and coil packs for good measure. Everything went ok for a day and it stalled again. This time throwing fault code 46. This time a little bit of fiddling with the CAS connector got it going, I've been down the CAS path before so we replaced it last night.
This morning it stalled again, and is throwing no fault codes at all (code 12 only). It cranks strongly (new battery), the fuel pump can be heard priming, but it won't fire at all. I have no idea what to do now, I've fixed the parts that I thought were giving me grief and still the problem persists.
