Help with shudder on VF Calais V S2 2015 V6
Stevebermandy
VF Calais V S2
Hi all,
Hoping to receive some thoughts on the below problem.
I own a VF series 2 calais v v6 2015 with about 120,000KM on the speedo.
I experience a slight shudder at around 55km/h, but can happen at other speeds (happens more frequently at lower speeds). It typically happens when I slightly apply the accelerator and when on an incline. Interestingly, car will never shudder right when I start driving and within about 20-30 mins. It never shudders super violently, just subtly.
Taken to a few trans specialists who can't tell me conclusively unless they open up the trans. I have had mixed opinions between engine misfiring to torque converter. But no one had conclusively figured it out.
I bit the bullet and took it to Holden for a diagnostic test and they suspect it is a torque converter issue. Their reasoning is that when they turned the torque converter (turned the ' TCC off') the car stopped shuddering. What worries me is they found no error codes besides at P2888 which is apparently unrelated.
I want to avoid fixing the torque converter which they've quoted $3K for unless I can be 100% sure that's the part to blame.
What concerns me is also the difference in opinion that alot of people have.
I appreciate anyones insight to this apparently common problem with the VFs.
Thanks
Forg
Regal Peackock VF SS-V Redline Wagoon
Stuff like this can be a total PITA to diagnose, it can be about spinny bits being in balance for example … our 1995 Berlina had a strange strong vibration that happened maybe once a year & when you stopped it’d go away without the ability to reproduce. Kept happening for 5 years ‘til we replaced the rear tyres then never happened again.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
How is the trans fluid level? Any visible leaks under the bellhousing.
Not uncommon for V6 torque convertors to develop cracks.
Stevebermandy
VF Calais V S2
No visible leaks - the trans guy I went to checked the catchment and nothing yet.
David Delf
75
Rowville Melbourne
VF Calais Series 2
Hi all,
Thanks
Hello Steve, I was very interested to read your post as I have exactly the same problem with my Calais VF Series 2. I have put up with it for a while but I really need to do some thing about it now. Before I go down the path of an automatic transmission specialist, I was wondering what the outcome was of your own situation. By the way I did have the plugs and ignition leads replaced but did not really improve things too much. I would really appreciate any help/advice you can give me.. Thanks
Skylarking
123
Downunder
Commodore Motorsport Edition
Hopefully @Stevebermandy will get back with some info as he was last seen on the forum “yesterday”.
I’m also curious what his outcome was considering that shuddering would go away by deactivating the torque converter clutch. In such conditions I’d consider the TC faulty and would want it replaced under warranty as TC‘s should last for decades and 100’s of 1000’s of kms. Obviously the dealer just wants things done at commercial rates as they are much more profitable than warranty work.
A batch of TC have been known to be faulty in manufacture and have had issues with cracks on the pump snout(?) and I’ve heard of other issues with clutch engagement and wear, just can’t remember which models and timeframe these issues were supposedly isolated to.
For me anything pointing to a faulty TC clutch I’d want fixed before metal starts flying around with the fluid causing more issues. But I’m not an auto trans expert and may be I’m just too worried at auto trans failures due to their complexities and cost to repair. Regardless, I hate vibrations and shudders as it upsets my smooth car ocd :p
wetwork65
A wet business
VF SSV Wagon & VF SV6 Wagon
I guess I get frustrated when questions are posted, then the OP disappears.
Knowing the outcomes and fixes would help other forum users in shortening the fault finding process, myself included, as I may be chasing a similar fault. Working out if it is the transmission or ignition/injectors is tiresome and very expensive these days.
This issue of shudder which may or may not be from the Torque Converter seems to be common e.g. one similar thread is https://forums.justcommodores.com.au/threads/torque-converter-issues.304328/ This OP has similarly disappeared, although it has only been couple of days.
