High idle issue on VN 355 and IAC pinout
Immortality
Staff member
Sth Auck, NZ
Unplug and remove the IAC, measure the depth of the IAC port on the throttle body and extend the stepper motor pintle so it's just a bit longer than the depth of the port. Then refit the stepper motor (this should fully block the idle bypass passage). Then start the engine and see what the idle does and if possible adjust the throttle body butterflies so it idles 600-650rpm (assuming it's a mild build with a small cam) or to and idle speed 50-100rpm where you would expect it to idle (has it been tuned? What idle speed is commanded?). Then plug the IAC back in and see what the idle does.
VoodooVn
45
VN SS s1
It has been tuned but I don’t know what idle speed is commanded. I know my engine won’t idle at 600-650 rpm. 355 cube, 10.8/1 comp with solid cam. I went back to my tuner On the weekend and he showed me on the laptop that the iac was commanding a high number of steps but the iac wasn’t opening. When I drive the car and slow to a stop it idles high at 2000 rpm and rpm only comes down after I come to a complete stop.
Immortality
Staff member
Sth Auck, NZ
Ok. I'd probably start at a 1000rpm with something like that.
VoodooVn
45
VN SS s1
Yep it’s a lot happier around those revs . The throttle body is brand new. I previously had a Holley throttle body with a Chrysler style stepper motor and I had the same issue. Changed to the edelbrock as it has all GM sensors and iac but it didn’t change anything. I was told the IAC would work with factory IAC wiring positions but I’ll check it all based on the info I’ve got from you guys.
Immortality
Staff member
Sth Auck, NZ
Have you tried swapping it out with an original Holden IAC stepper motor?
VoodooVn
45
VN SS s1
No I haven’t. I’ve only just bought it and was hoping it would work out of the box being all GM sensors. I’ll definitely give it a go though if all else fails
VoodooVn
45
VN SS s1
Any chance of an air leak in a vac line or gasket?
All new lines etc. I’ve checked for vac leaks and also there weren’t any manifold vac leaks when the engine was on the engine dyno. Was thinking that a vac leak would always be there also.
vt6banger
Major Procrastinator
high wycombe wa
VK SL 355
the holden IAC wont work in it if its a edelbrock 3878, the iac needle is way longer.
