4ONTHETREEVS
- Oct 21, 2022
- 29
- 12
- 3
- Age
- 38
- Location
- Perth
- VS 2 ute
Hi all. I have a VS 11 97 UTE V6 auto.
My high speed thermo fan kicks in as soon as the key is on. I've had the mechanic run the scan tool and confirmed the low speed fan is coming on at set temps as per Holden states.
The temp probs resistance changes as per manual says The high speed relay is getting a out put from the ecu.
I've swapped high and low relays with no change.
I've currently pulled the high speed relay out and just running on the low speed fan as normal.
Anything else I may have missed or you could suggest to check.
Thanks
Thanks
