Holden Statemans
Zues German
51
New Zealand
Holden Statemans
Hello,
I have a Holden statemans with Abs and Traction control light on.
Used ABS fitted in but light is staying on. Drove vehicle after 20 min light goes off.
Now the warning lampd is on again.
I cannot read faults as my scanner cannot identify or communicate with abs/traction ecu. Anyone had this problem.
Also anyone with wiring workshop manual.
Fu Manchu
WA.
What sort of Statesman? Which model?
Zues German
51
New Zealand
Holden Statemans
Year: 2000
Make: HOLDEN
Model: WH
Colour: RED
Second Colour: GREY
Submodel: STATESMAN V8
Body Style: Saloon
VIN: 6H8WHY19FYL568870
Engine No: VF000101439
CC rating: 5,737cc (5.7l)
Fuel Type: Petrol
Fu Manchu
WA.
Only the higher end scan tools will be able to poke around with ABS module codes.
Until we know what those codes are, there is a heap of lucky guesses to be made.
Fu Manchu
WA.
I’m not sure if WH had to have the module linked to the car. Others might?
Zues German
51
New Zealand
Holden Statemans
Yes, you are totally correct.
Zues German
51
New Zealand
Holden Statemans
So the light stayed on after fitting a secondhand abs pump. Only when driven for 1 hour or so light went off. Once ignition was switch off and started vehicle light is back on, now.
I hope I can get a workshop manual, but it is really difficult to get one.
Fu Manchu
WA.
You will find a factory workshop manual as a download for free. Some quick googling.
