my ongoing saga with this money gulping piece of VE crap
07GTS
Australia
VEGTS BUILT BLOWN E85
as i was thinking the wheel sensors are inductive it seems like the VE they are not ( changed style after VZ) so since yours have 12v to one side and the other just closes as the teeth go past it may not have any resistance to test for and may be as simple as a reed switch within and a magnet on one side and when the tooth passes by it disrupts the magnetism and causes the pulse (guessing on that one tho) but it will just be a simple switch of sorts, should be easy to test on bench knowing the power in and just put it next to metal and it should close circuit then putting power out the opposite terminal, same way u can test it in vehicle know 12v in put multimeter on other wire to see if it pulses with power as wheel turns, or encase its another style sensor the 12v supplied power will drop to zero and back ''pulsing'' as wheel is turning very slowly, if no power changes what so ever then that is an issue
Fu Manchu
Auto Correct is not my frog ballet.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8, & ya mum.
The info you need is in the factory manual which you can download with a quick search.
Fu Manchu
Western Australia
I can’t spoon feed this info. We all have busy lives and the manual is extensive and complex. You need to start going through it and learning it.
We just have to do this now days.
When testing pins, never ever push anything into the pins. You can spread them and creat a whole new world of painful faults.
Fu Manchu
Western Australia
yep and we are supposed to be advancing, as i mentioned previously you should be given the option to buy or given a scanner and a how to book for dummies when buying these new car.
It’s not even that easy.
No one should view the world through the eyes as a victim. Be proactive.
Get learning. Get a decent scan tool.
For me it was being charged $325 by an auto sparking the crimp in a generic bulb connector in 1994 that got me buying books about auto electrics. Then friends wanted stuff done. Then I stopped being ripped off. I’m still learning and doing any free diagnostics training on line that I can find.
Fu Manchu
Western Australia
That suggests the fault is else where. I’d investigate where they all come together.
gazzat
67
cecil park
ve 3.6L commodore omega automatic
as i was thinking the wheel sensors are inductive it seems like the VE they are not ( changed style after VZ) so since yours have 12v to one side and the other just closes as the teeth go past it may not have any resistance to test for and may be as simple as a reed switch within and a magnet on one side and when the tooth passes by it disrupts the magnetism and causes the pulse (guessing on that one tho) but it will just be a simple switch of sorts, should be easy to test on bench knowing the power in and just put it next to metal and it should close circuit then putting power out the opposite terminal, same way u can test it in vehicle know 12v in put multi-meter on other wire to see if it pulses with power as wheel turns, or encase its another style sensor the 12v supplied power will drop to zero and back ''pulsing'' as wheel is turning very slowly, if no power changes what so ever then that is an issue
from what i have been able to gather so far is there should be +12v down one wire then as the (i am guessing here) magnet passes the tip of the sensor creates a magnetic field with in the sensor and send the signal up to the EBCU, so this is similar to a crankshaft sensor or a camshaft sensor where they usually have +5v down one wire then when the trigger happens it sends the signal to the ECU so as to know when to squirt fuel in and when to fire, it is a bit like a lawn mower where you have the permanent magnets pass the coil and create an magnetic field collapse and with the aid of a set of points and a condenser we got the high voltage spark, so that has all changed now similar to cars and have electronic ignition, but basically everything must have a way of creating the pulse signal and this is what i am going to trace down, i will not stop at this till i have a positive outcome and not by chance but by pure thought,logic, and testing.
gazzat
67
cecil park
this is correct that is why i have been asking questions, i will repeat my self, you don't just driving along then all of a sudden chimes start going off warning you the you have a wheel speed sensor issue. so upon further investigation it shows i have a fault for each wheel sensor (so one common output or input signal) that the ABS is showing the fault, so i have been in this game for 40+ years but things are just growing at a rapid pace. Take a look at when computers first started, i brought a commodore Vic 20 with mainly a tape back up system (floppy drive was dear and people just could not afford it), then next thing it was a c64 with the floppy drive at a greatly reduced price,then next the c128, then the Amiga 500, then the Amiga 1000 then the Amiga 1200 the PC market just kept growing and growing as is with cars, they are developing things and putting them on cars quicker than mechanics can keep up with the technology and then they have to have all this testing equipment that will either find the fault very quickly or the customers car stays in the workshop for a week while they get a lend car.
