Hi all, I am about to fight tooth and nail with Holden Australia as I to have been stung by the timing chain issue with my 2007 Holden Captiva LX Petrol. Currently I am waiting for a call back from Holden which I expect tmrw and need some ammunition to back up my case.
The local mechanic advised me of the following codes to supply to Holden:
P0300, P0017, P0016
I have a full log book history and am the second owner. I brought the car from a dealer at 99000km 2 years ago (so that would be just on the 5 year manufacturers warranty) which is no doubt why the previous owner sold it, now it sits on 140000km. A few months after I purchased the Captiva I got the engine symbol on the dash took it into the mechanics but they could not fault it putting it down to a dirty sensor or something; the car was fine or so it seemed. 2 years later I am here about to embark on the little person against Holden.
Any advice would be much appreciated.
Thanks,
P0300, P0017, P0016
Thanks,
Basically a timing chain should last for the life of the engine and the GM made the wrong design choice when using a lighter chain to quieten the engine which resulted in stretched chains.
Good luck.
suck it up princess, car is 7 years old, get over it and pay for it, its out of warranty clearly.
No it shouldn't last the life of the engine ffs, an average a timing chain is changed every 120,000km to 160,000km depending on the engine and the way its driven and serviced.
Its a moving part that is under tension, they stretch and wear out, thats life.
You treat the car like ****, miss service intervals, **** oils etc etc etc they are going to #### up faster.
If it's a known issue then you shouldn't have bought it. If it's out of warranty then it's out of warranty, op should be happy they covered most of the cost. The timing chain was a part that wore out with time and needed to be replaced. Do you expect them to replace your tyres and brake pads when they wear out? I think not.
Nothing is infinite. On a 7 year old car one would and will argue that it is through wear and tear that a part has failed and not a manufacturing error as was happening in half or less time on the other engines.the point is that it was a known issue to gm/holden
warranty is one thing but consumer law is another
and no, no one expects a manufacturer to replace consumables like tyres and pads
unlike a timing BELT a timing CHAIN is not scheduled service part, the notion that they should be routinely replaced at 120-160k's in a properly serviced engine is nothing short of ridiculous.
