Ryan272
- May 24, 2009
- 31
- 0
- 0
- VZ Lumina
You'll also need one of those small relays in the second picture I sent.
The diagram that markovr posted I'd imagine is dealer only info as it refers to retrofitting cruise to VR models using a patch cable whereas you are fitting it to a VS without a patch cable.....basically 'plug and play'.
When you plug the cruise module in make sure the connectors are clean - mine were full of dust etc and needed cleaning with a toothbrush and solvent. Also make sure there is no way the cruise module throttle cable can come in contact with the exhaust manifold as someone on this forum had that happen - result was a wide open throttle when the cable melted.
ahh k. i see now.
alrightee. ill be giving this a bash in the next week or so, ill let you know how i go. thanks for your help.
