Forg
- Jun 16, 2015
- 6,238
- 4,241
- 113
- Location
- Sydney
- Regal Peackock VF SS-V Redline Wagoon
I have my doubts ... I don't know where the sensor is or sensors are, but the car knows when the key is inside it, whether that's in a handbag on the very edge of the rear seat or it's in the centre-console. Yet if you stand really close to the closed front door, it knows the key is outside the car.Can you hide the key in the boot somewhere far away enough from the doors to just let you access the boot only?
It lets you lock the car if the key is inside, doesn't it? It just beeps at you? So if you got a key cut but with no electronics, you can probably still lock & deadlock it with the key locked inside - although no immobiliser. You might even be able to disable that rapid beep-beep-beep it gives you when you close the key in it, ie. in MyLink.
I may have to try it this evening with the spare key ... lock one key & key-fob inside, using the other key mechanically in the door-lock rather than the remote central-locking ...
