[VT-VX] How To Change Your Wing Mirrors (May apply to most cars)
djdomohudson
Mad frogs
Werribee, VIC
VE Omega Sedan / VE International Sportwagon
G'day happy muffin top children and petrol headed nuggets :)
I have coveted mirrors that match my paint code ever since I bought my car.
I thought the black ones were pretty scum.
So while I was out today I happened to spy one and I bought it. Yes, one, but I'll get the other soon. The guy in the wreckers only had one so I got it off him cheap, $40.
So I had a poke around the site and found not much of an explanation in to how to actually get them off. I watched a youtube of some american man with a weird accent take his off and I put two and two together. Then I rushed outside with my screwdriver and a camera to show you this lovely transformation!
Here goes.
What you'll need:
-Wing mirrors the same colour as your car, or new ones to replace yours if they are broken.
-A screw driver
-About an hour.
Step 1
You'll need to take off the inside door card to gain access to where the mirrors are bolted onto the car. Read THIS article and follow it. (Ignore the part about the speaker grilles).
Step 2
Put your door card somewhere else and you'll be able to have a closer look at the back of the mirrors.
Note the black circles pointing out the three screws that hold the mirror in place:
Step 3
Unscrew these screws just a little so that you'll be able to undo the rest by hand.
This is how long it is:
You'll only need to unscrew it by hand a little bit and the rest (about 3 cm of it) will just come out of the hole.
Step 4
After you've removed the three screws and put them in a safe place, just pull the mirror outwards from the top.
Step 5
You'll need to disconnect the wire loom by this clip marked in the circle.
Step 6
Replace your new mirror, connecting the wire loom first.
Step 7
Screw in your three screws, making sure the mirror is tight.
Step 8
Check that it works!
FIN.
Now admire your work :)
Repeat for the other door, and retrace Step 1 to refit your door cards in place so that your car is back together and pretty.
Happy travels!
Luke52
Mulgrave, VIC.
'07 VZ Acclaim wagon.
Awesome write-up mate, great work!
xVTx
SA, Adelaide
VT Berlina
Great write up mate, might have to change my dodgy passenger side one soon after seing this!
itsagixa
VX SS
Good work mate, detailed writeups like this help all the new kids to the block
Nut Kracker
Donating Member
60
Echuca Vic.
VT SS 304ci (195i)
Great write up mate. I was gunna check the wiring in mine. The Gregories doesn't mention removing the door trim, just
the demister duct and the mirror trim cover. I will have to alow a bit more time now.
Kdouble
Chirstchurch
VT Berlina, CX8 Adventra
^^^^ If my memory serves me then that's right you just can just pull the demister duct off without having to touch the trim.
djdomohudson
Mad frogs
Werribee, VIC
As far as I could tell, there was no getting access to those two lower screws without having to have a torque driver and then, the length of the screws themselves would make it difficult to remove them in the tiny hole you can find underneath the demister vent...?
djdomohudson
Mad frogs
Werribee, VIC
Just dropped outside and pulled off the window vent and this is as much as you can see.
The top screw is clearly accessible but the other two are beyond the door trim... So it'll have to come off. But this is on a VT. It may be different for say a VY or a VE..?
Nut Kracker
Donating Member
60
Echuca Vic.
VT SS 304ci (195i)
View attachment 153671View attachment 153672
Yep.....the same on my VT....the door trim has to come off.
Your mirror has been changed djdomohudson. Or did you remove it? The sticky insulation stuff has been removed.
When I checked mine, the insulation was totaly covering the screws and bolts.
