Daniel Souza
- Jan 7, 2017
- 531
- 646
- 93
- Age
- 46
- Location
- Glenwood
- VF2 Wagon SSV Redline
I trialled HPAcademy. Not much useful info I found. They give a good basic background knowledge, but the same info is available on youtube, websites and forums. MAF helps with calculation of fuelling. It measures actual airflow but still won't make adjustments in target afr's, timing, torque management etc. Basically you adjust the fuelling so that commanded and actual AFR's are the same and then adjust commanded afr's from there.
You can keep the MAF - it'll give slightly better fuel economy and better manners at low throttle openings. But that's not the case when large aftermarket cams are fitted due to intake pulse and reversion upsetting maf readings.
You'll spend more than the bloke above suggested getting set up with hptuners, credits and wideband. It's not a cheap exercise. Then you really need to learn how to use it, which can take years, and you have the risk of damaging your vehicle and the likelihood that you won't get decent power and economy out of it.
Spend the money and have it tuned by a professional with a dyno. Had mine dyno tuned about 8 weeks ago for $400 and it was worth every cent.
In regarding to the hptuners, credits and wideband cost, hopefully, I will be able to prove it can be done close to the price I mentioned before.
Price from VCM store :
- MPVI2 $499
- 2 Credits $164 ( I had quoted 1 credit before)
CarmodsAustralia
- AEM X-Series OBD2 $314.96
Gasket and Sealant $50
Installation DIY ( pictures coming soon) apart from welding the bung. Lets see how much they will charge me. I will remove and take the pipe (CAT piece) to the shop.
Even if you have to pay for the full install of the wideband, it will be less than the $1500 budget.
Please let me know if I am forgetting something.
