sundaydriver
- Jan 9, 2017
- 122
- 6
- 18
- Age
- 44
- Location
- Queensland
- VH 202 Blue 3.3 Vactioner
OK - here's another curly one.
No spark at plugs, so worked back to the coil.
With the dizzly lead off and the ignition on (so still have the dizzly looped in with + and - contact leads) - there is no voltage on the contacts (just using a multi-meter)
The workshop manuals tell me there is something wrong with the 'ignition switch' if there's no voltage at the coil, but i'm not sure that's the issue because
I can't, however, make the coil secondary give off spark. I don't have a test light or plug, so all the testing has been done with the DIY methods on youtube - i.e. grounding tests with the ignition on.
Also here are the reading from the new coil i got a few months back (it had been running OK on this until recently) and as a comparison, I have the original (30+ year old coil) that came with the car - I only replaced it for the sake of it, not because it failed.
So you can see the new coil primary is pretty high...
The manuals say the primary should be somewhere between "0.5 -0.7 Ohms". So the old coil comes close. And the Secondary is supposed to be between "5000-7000 Ohms". So they both look OK for the secondary. But again, can't get spark of either
New coil
Primary - (metre @ "200" ohms) = 66.1 <-- not a misprint.
Secondary - (metre @ "20K" ohms) = 6.40
Old coil
Primary - (metre @ "200" ohms) = 0.9
Secondary - (metre @ "20K" ohms) = 6.82
- When the ignition is on, all the accessories and headlights work
- It can crank - so the starter works too
- With the ignition on, using a multi-meter, I can probe the pos. lead going to the coil and ground and get ~12 volts - so I know power is getting there
New coil
Old coil
